Original => Hot Tub Forum => Topic started by: vfitom on December 18, 2015, 05:08:08 pm
Title: Setting hot tub temperature
Post by: vfitom on December 18, 2015, 05:08:08 pm
Hello all. Newbie here. A question I have is the following: Should I set my tub to a desired temp and leave it there, or after each use, bump the temp down say 5 degrees or so and then bump it up when I want to go in? What is more efficient? We use 220 amp service to heat it. We get cold nights here in NE USA and I want to conserve energy use....Thanks
Title: Re: Setting hot tub temperature
Post by: Vinny on December 18, 2015, 07:15:29 pm
leave it.
Post by: Tman122 on December 18, 2015, 08:01:29 pm
Up and down can be a little more efficient but.............quarters, not dollars.
Post by: wmccall on December 21, 2015, 09:21:51 am
Agreeing with that, I want to go out when I want to go out, not an hour later.  My tub heats around 6-9 degrees per hours. I don't want to turn it up and then go back an hour later.
Post by: Racenut on December 21, 2015, 08:17:23 pm
We leave ours set where we want it all the time.  But we use it almost everyday.  If we go on vacation or something, I'll turn it down.  If we were only using it on weekends or something, I might turn it down in between.
