Original => Hot Tub Forum => Topic started by: jmauceri on October 07, 2015, 04:47:40 pm
I have a 2008 Marquis Epic with the Spa Frog System. I use my tub every day and after trial and error I found my water would balance well if I shocked (non-chlorine) every time I used the spa. After some time I realized my Ozonator wasn't working. I said "ah ha! that's why i have to shock daily to keep by bromine levels where they should be". So I replaced the tube style stock ozonator with a Del Ozone MCD-50 ozonator and figured life would be good. Well the opposite seems to be. Unless I shock daily my bromine levels read zero! Before knowing this, and after a few days of not shocking, my water started getting cloudy. What's up with that? I thought ozone helped reduce chemical use. I'm going through more shock than ever!
If a chemical genius could explain this to me I would greatly appreciate it.
FYI Spa Fog at setting 4 and PH, Alkalinity and CH at the middle of the spectrum.
Did you ever add sodium bromide to create a bromide bank? If not, then the ozone has no bromide to convert to bromine. Eventually your addition of bromine may build up a bromide bank, but initially you need to create one.
Wow, I had no idea. Thank you so much. Why wouldn't marquis include that little tidbit in their startup instructions for the Spa frog system with the ozonator?
Sorry to be a pest, but would the Spa Frog Jump Start pack of Sodium Dichloro-s-triazinetrione provide the base bromide? I'm due for a routine water change, so I'm wondering if I need to still add the sodium bromide to the new water.
No
How did you know your ozonator wasn't working? I've often wondered about that with our spa. I know there's a stream of water coming out of the outlet, but how does one know that the ozonator is actually doing anything?
A few different ways. First, the O3 message on my display would only stay on briefoh. Second, there was no glow from the ozonator itself. After I replaced it, is completely obvious because I can now smell the ozone.
I want to give an update to this thread. Chem Geek was dead on with his advice. I performed a water change and I used the Spa Frog Starter packet along with Sodium Bromide. It's been over 4 weeks now and my water has been crystal clear from the beginning and I'm now only shocking one a week with the ozonator running well.
Chem Geek, thank you so much for the advise! I still don't understand why the manufacturer wouldn't recommend the Sodium Bromide.
Regards,
Joe
There are lots of things about pool water chemistry that manufacturers either don't know or don't tell. However, most do recognize that for a bromine system one usually starts out by creating a bromide bank by adding sodium bromide. That was a pretty lame mistake for them. Most don't understand the chlorine/CYA relationship and many don't understand the TA/pH relationship. There are good ones that do understand these things; you'll find them on this forum.
