Brand Specific Forums => Jacuzzi Hot Tubs => Topic started by: NewToSpas on June 04, 2014, 08:51:15 pm
I pulled the trigger this week and bought the J-365 model. It arrives next week but my patio is being installed now (tomorrow). Wondering if anyone had the dimensions associated with the location of the Pwr Inlets? Need to have the mason run a conduit under the brick from the house to the Pwr inlet on the left side of the tub.
Thanks in advance!
Forgot to mention that I purchased a 2014 J-365 model.
I just recently( last week) had my j365 installed and hooked up. The power knock outs are located on the front left and right of the unit ( where the control panel is). Now my electrician chose to come inform the back corner with a piece of flexible PVC ( liquid tight). The liquid tight is to big to fit throughout the manufacturer power knock out area. I will try and upload a picture when I can. Good luck and enjoy, it's only been a week and it's been great already
We just installed as well. The composite base measures about 75" from back to front, with the knock out on the front left at 72" from the back corner of the base. The tub frame overhangs several inches on all sides, so if you take your 91x84 tub layout dimensions and shoot for your front left corner, inset a couple inches both ways you'll be right there for a flex or an elbow to take you right in....
Good Luck, you will love it!
Thanks for the responses.
Looking forward to enjoying our first soak!
