Original => Hot Tub Forum => Topic started by: carwhisperer on May 15, 2014, 11:09:25 am
I bought this yesterday for $50. I like the fact that it is very light. I only needed one other person to help me move it. I can't find a brand or model number on it but I did find a serial number: (21)030813110 and another number 81245600102 and a number on an electrical box, HT 1000 MB. The google didn't come up with anything for any of those numbers. It appears to be missing a sensor, the location of which is shown in one of the pictures. It seems to be a pretty simple unit. Can you help?
(http://i140.photobucket.com/albums/r12/914turboford/HotTubStanding_zpsb4a0fb6b.jpg)
(http://i140.photobucket.com/albums/r12/914turboford/HotTubBox_zps34ab233f.jpg)
(http://i140.photobucket.com/albums/r12/914turboford/HotTubSensor_zpsecfba339.jpg)
(http://i140.photobucket.com/albums/r12/914turboford/HotTubBox2_zps2c972fec.jpg)
Well its a roto mold spa, pretty sure it's not a freeflow, might be a older dream maker maybe? The sensor missing is either a high limit which I think is the one in there the other was a temp sensor.
Doesn't really matter what brand the tub is. JJ is correct, it could be Dream Maker, but what you need to know is that the control box was made by Len Gordon. The "HT" part of the model number means the tub has no heater. What? That's right, no heater. It used "Heat Transfer" from the pump and or pump motor to get the water hot. Takes days to get up to temp in cold weather, and can't keep hot in freezing temps.
You may find info on line about a replacement system which has a model number of HT-1000-Y2K, but I strongly recommend you replace it with something different: something with a heater. There are 'Plug n Play' systems available, they have a 1000 watt heater (which can switch to 4000 watt if you go 220 volt). Those can plug into most any outlet on 110 volt, hardwire on 220 volt.
BTW - yes, there were two temp sensors. Normally, there would be one on the tub and one on the heater, or one on the inlet to the heater and one on the outlet from the heater, but when there is no heater, they put them both on the tub.
HTH
Thank you so much for the help! As you indicate, based on the diagram on the electrical box lid, that must be either a hi limit or temp sensor. Do you know how I can test to determine which of the two is there and how I can find a replacement for the one that is missing?
