Original => Hot Tub Forum => Topic started by: pkingroch on June 20, 2004, 08:23:47 am
Title: Monarch Silver Cartridge in Caldera Spas
Post by: pkingroch on June 20, 2004, 08:23:47 am
Our spa was delivered yesterday, but we can't find the monarch silver cartridge anywhere.  We purchased a Geneva Utopia.  Setup/delivery by our dealer has left us with several issues and the dealer will be bringing another one out for us as well as fixing the problems created by the first delivery crew.
My guess is that the sivler cartridge similar to Nature2.  Can anyone comment on this system?  Pricing?  Effectiveness?
Thanks!
Paul
Title: Re: Monarch Silver Cartridge in Caldera Spas
Post by: tubin on June 20, 2004, 10:27:13 am
PKingRoch,
Yes, the monarch cartridge is made by Nature2...I double checked this by looking at mine (Geneva Utopia too) and it has Nature2 molded on the side of it.  It is just Nature2's brand sold only to Caldera.
If it is in your spa, it is actually inside your filter.  easy to check,
1. just pull up and out on your waterfall/filter lid and the straining basket (floating weir basket) is seen
2.  turn the base of the weir counter clockwise(at the notches on the top of the base that is not floating)
3.  once it turns a little, lift the weir straight out of the spa.
4.  now you should see the top of your filter
5.  grab the rail/handle on the top of the filter and twist it either way while pulling upwards (it doesn't screw on/off, just slips over a filling in the bottom.
5.  now the pull the filter out of the spa (it is tall) and look inside the opening in the bottom of the filter.
6.  if it is not there, then look in the bottom of the filter well, it sometimes will fall out when you take the filter out.
Well if it isn't there, you didn't get the cartridge.  as far as price, my dealer asks $30 dollars for one  :o and I have seen them vary from 20-40 dollars on the net.
As far as effectiveness, I am almost to the end of my 4 month use of mine and I am planning on trying the spa without the cartridge.  I have yet to hear an ACTUAL testimony from a user that has tried with and without the cartridge.  There is certainy enough debate whether or not these work.
I will post my findings in later (maybe July/August) but it all depends on when I choose to drain the tub.  I have the identical tub as you do so keep an eye out for me in the future as I plan on giving a detailed analysis of my findings here.
Good luck w/the install #2
Post by: pkingroch on June 20, 2004, 11:22:25 am
Tubin,
Nope, it's not there.  There is a plastic sleeve, that the filter fits over and then fits over the suction inlet, but no mineral cartridge.  Again, the dealer should be bringing another one today.
The Nature2's can be bought on the web for around $10 each if you buy in quantity - any ideas on a suitable replacement?
Thanks - we'll see about install #2 and post later.
Paul
Post by: johnnythunders on June 20, 2004, 12:54:48 pm
Where can i buy the nature2 for around $10 on the net.I can buy 12 of them.johnny Thunders
Post by: tubin on June 20, 2004, 02:30:36 pm
Where did you see this good deal?  You definitely peaked Johnnythunders and my interests!
I don't know of another mineral type treatment for your spa that would make a good replacemet to the Nature2 cartridge.  They may hold a patent on the process and the corner on the market for now.
I am hoping that I find no difference in my chemical routine (low dichlor/chems, virtually no smells, burning eyes, etc) after I stop the Nature2.
Please post a site where you found the ~$10 price...the lowest I can find is around 19 dollars for 4 cartridges.
Post by: johnnythunders on June 20, 2004, 02:45:57 pm
Unless you go on ebay and buy them.Johnny Thunders
Post by: pkingroch on June 20, 2004, 09:52:40 pm
Ebay is it - check these out.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=20729&item=4307889104&rd=1
Post by: pkingroch on June 20, 2004, 09:55:02 pm
To me - that's about $5 each - where did you find this?
Post by: Spatech_tuo on June 20, 2004, 10:21:25 pm
Are these new cartridges or is someone selling their old ones for $5? If its old ones you're looking for I can get you some for $3 each! :o
Post by: pkingroch on June 21, 2004, 06:48:23 am
The ones I saw in the link above say they are new.  I haven't purchased any to verify.
Are these cartridges all the same size, or do they come in different sizes?
Post by: tubin on June 21, 2004, 09:56:20 pm
 ;D  ;D  ;D
ha ha ...oh boy,
i just re-read my earlier post about the "19 dollar for 4" deal....SORRY i wrote it down wrong!
i feel like a dummy now, well the cheapest i saw the cartridges for was a buying 4 at a time for 19 a piece.
that does bring up a good question, how do you know if you are buying new cartridges off ebay or someone's used cartridges?  i looked at mine and it is about 3 months old and still looks the same....hmmm.
i could only find the spa cartridges from nature2 in only one size.  i think they come with extension rods that snap into place to make it longer if needed.
Post by: Spatech_tuo on June 21, 2004, 10:28:32 pm
Don't worry, you'll know if its a used one simply by looking at the silver beads. Once you see a used one you'll know what I mean.
Post by: autoplay on June 21, 2004, 10:45:20 pm
I can't answer as far as if they are the same product.  I can tell you,I have a 2003 Geneva Utopia,and I use the nature2 with di-chlor,and I shock about once a week.
Very easy to install......only tool needed is a hack saw,to cut the length to fit on the yellow plastic extension/s.
I change my nature2 filter about every 4 months.
Post by: pkingroch on June 22, 2004, 07:39:15 am
autoplay -
Hacksaw, really?  We just had a geneva utopia delivered and the dealer brought out a Nature2 cart for me.  I put it in, but I didn't use both of the extension rods, I just used one.  I figured that as long as it wasn't on the bottom blocking off the intake it would be ok.
So, you di-chlor with a weekly shock.  What do you normally keep you PPM at?  I was reading the material that came with the spa and Watkins recommends 3-5 ppm, but I've read on the net that 1-3 ppm with Nature2 is supposed to be good (with a weekly shock of course).
Comments?
Thanks!
Paul
Post by: Spatech_tuo on June 22, 2004, 11:35:38 am
The reality is you can use the hacksaw and cut the extension to your desired length quite easily. The question I have is 4 months down the line when Autoplay has to replace the cartridge, does he throw away the old extension and pull out the hacksaw again to cut the new extension or does he take the shortened extension off the spent unit and simply connect it to the new one?? ;D ???
