Original => Hot Tub Forum => Topic started by: beachman on June 14, 2004, 06:54:53 pm
Title: from beachcomber to cal spa???
Post by: beachman on June 14, 2004, 06:54:53 pm
I've owned a 740 beachcomber hottub for 1 1/2 years now and i've been haveing jets pop out ever since i've gotten the thing. I 've also have a lot of blistering all over the cover. Iam now looking at getting a different spa. I've wet Tested,hotsprings,catalina,jacuzzi,sundance and now looking at cal spa, but haven't wet tested it yet. just wondering if any of you know about this spa.(or if i'll end up with another lemon)
I looked at the cal spa and looks like a well built tub and the water pressure from the jets is quite powerful which is something iam looking for.  any take on this tub!!?
Title: Re: from beachcomber to cal spa???
Post by: Spatech_tuo on June 14, 2004, 07:01:31 pm
Do a search on Cal Spa here and other sites. I think you may change your mind on them after doing so.
Post by: beachman on June 14, 2004, 07:08:06 pm
I would like to but the jets keep popping off....
I really don't think that there is a really good tub out there!! I think were all searching for something that doesn't exist!?
Post by: Steve on June 14, 2004, 07:14:46 pm
if these 2 issues were resolved, how would you feel about the product you have currently?
Post by: beachman on June 14, 2004, 07:24:38 pm
beachcomber has been in business for how long?? 20 years?? how can they be having jet problems now? this item should have been resolved along time ago..
There is nothing more embaressing than having your friends over in the tub knowing you spent 11000 on a tub that keeps popping off jets. also the really small jets I've had to replace afew times because they wont stay in place. if it wasn't for the jets and cover i would say beachcomber is a pretty good hottub. But when you think of a hottub, one of the most important items is the jets. its like getting a new car with an engine that doesn't work...... and when I have the jets on low speed some of the jets wont turn they get stuck??
and some well go and stop and then go again and stop.
so I have to ask beachcomber hey! whats going on here?
Post by: Steve on June 14, 2004, 07:36:16 pm
These are not the same jets we used 26 years ago believe it or not.
Again, this issue was resolved and the new R4 jets work perfectly. Any of the jets you are having problems with should be replaced with these new ones. Problem fixed. The search for a new spa hopefully will be eliminated.
If I sound a little "short", it's because these are such minor issues. The idea of replacing the tub with a new one seems very shortsighted. I'm sorry that your dealer isn't looking after this as quick as you would like but that's why I gave you a direct number to Beachcomber if you are unhappy.
If you are displeased with the tub in general, then I could understand your feelings. I'm having a real hard time with this bcause that isn't the case.
Do what you feel is right. I've given you everything I can.
Post by: markb on June 14, 2004, 07:40:35 pm
A friend of mine owns a beachcomber and loves it. I know he did months worth of research and testing before his purchase. He says he's had no problems with his. We are going to go look at one maybe this weekend. The dealer is about an hour away.
Correct me if I'm wrong, but wasn't calspa the company that went BK a few years ago? Not trying to start a rumor but that's what I have heard here in N. Ca.
Post by: beachman on June 14, 2004, 07:50:26 pm
not sure, I did alot of research too and lots of wet testing. I went with beachcomber because of the comfort and was one of the best tubs for water pressure from the jets.  But I tell you, this jet problem is a real pain, I have forgotten how many trips i've made to return defective jets. I now also have to go to a different beachcomber store because the one were I bough the tub switched to dimention 1
Post by: RDF on June 14, 2004, 08:08:24 pm
I've had my 730 for about a year now. A few jets fell out so I returned them to the dealer. He gave me a box full of assorted jets and told me to replace any bad ones and keep the rest just in case, no problems ever since.
No blistering.. Anyway, I think that should be covered under your warranty..
Post by: OnMedic on June 14, 2004, 10:56:05 pm
Beachman
I am assuming you are in the GTA/Golden Horseshoe somewhere. The switch was made for $$$ reasons I beleive, and I am not sure but I would guess they are 100% committed to the Beachcomber customers after the switch.
Stick it out and find a dealer you have confidence in. Sounds like the problems you have had are now resloved and should be smooth sailing from here.
Post by: Pooldevil on June 15, 2004, 10:59:50 am
Hi Beachman
I know just where you are coming from !
As an ex Beachcomber dealer ... just think how we feel about all the problems !
Do what we did and change to "Marquis" ... the best move we ever made !
Post by: Steve on June 15, 2004, 07:55:26 pm
You guys are waaaay too dramatic for me. ::)
That's right my devilish friend... the grass is always greener on the other side.. ???
Let's jump ship... I mean the tub is falling apart right?  ;)
You guys... sheeesh...
Will you personally guarantee him Pooldevil that Marquis will never have any problems? Let me know that answer. Nevermind... I already know.
Post by: wmccall on June 15, 2004, 08:05:16 pm
Never mind
Post by: OnMedic on June 15, 2004, 11:12:11 pm
Beachman,
If your tub is really falling apart, will you give me a good price for it?
Post by: Lucas on June 17, 2004, 08:52:38 pm
Take a look at marquis.  They're as close to perfect the way a tub should be.  IMOP.
Post by: Rboehme on June 17, 2004, 09:31:19 pm
The problems you mention are fairly minor in the spa industry. They are not exclusive to beachcomber.
There is not one manufacturer that has built a problem free spa.
Post by: Jordy on June 17, 2004, 11:32:51 pm
I used to sell Beachcomber Hot Tubs. The jets popping out is quite a common problem and speaks to the quality control of the company that supplies the jets to Beachcomber, as Beachcomber does not manufacture the jets themselves (whose supplying them these days Steve?). It's not a huge problem, but it can be frustrating for the consumer, after all I'm sure you expected the Hot Tub to work the way Beachcomber said it would. Having said that, your local Beachcomber dealer really should be taking care of you better. If you are seriously interested in another Hot Tub, I would suggest you consider Jacuzzi Premium Spas, they seem to offer great value for the money.
Post by: Rboehme on June 18, 2004, 09:22:38 pm
In the years I have been in the industry I have seen many brands that had a problem with jets popping out. It is usually due to a problem in manufacturing that is not easily detectable. I.E. weak plastic, poor design, etc.. These problems affect many manufacturers because most manufacturers buy thier jets from the same few jet manufacturers.
Post by: beachman on June 21, 2004, 09:16:04 pm
I know that there is not one spa out there that's perfect.  But what would you call a spa that had
1. jets popping out constantly
2. filter lid cracked ( not covered, had to pay)
3. blistering cover
4. had an air leak from the air control valve
I tell ya, I felt like an idiot when i told people I payed
$10,000 bucks for this tub and these things are happening in the tub.
Customer service hmmm still waiting on them to come over and look at my cover so it can be replaced.  Once again I was told sometime this week..
When Life gives you lemons, Its time for a different tub.
Post by: Spatech_tuo on June 21, 2004, 10:31:00 pm
Talk to the customer service people at the manufacturer to help get the dealer to react. It can help quite a bit.
Post by: Chas on June 21, 2004, 10:44:30 pm
3. blistering cover
Well, I understand Beachcomber got some bad covers, but is ready, willing and able to take care of them. But since other people beside you are having trouble with them, it may take a couple of weeks of patience on your part to get it handled. You'll own this tub for many years, I bet you'll survive.
Filter lids are not meant to be used as seats. I'd be willing to bet yours didn't just crack all by itself. Am I right? Now, if you absolutely need to sit on the thing, take your new one to a boat place and have them fiberglass the back.
Jets popping out - go ask the dealer for some new ones - take the bad ones with you next time you go in to buy some supplies.
Air leak? I bet it was a minor issue, covered under the warranty. In that case, I bet you're glad you purchased from a big company like Beachcomber.
