Original => Hot Tub Forum => Topic started by: rosewoodsteel on December 10, 2013, 07:48:30 am
Question- Can you use spray foam "in a can" to replace dug out insulation after a repair?
I'm not 100% sure, but it does look like the same stuff they use from the factory, just larger cans. ;)
I think i'd agree with SR. It looks and feels like the same stuff.
I guess the only difference is theirs will be mixed on site by the gallon, ours will be in a tin ready mixed.
If i were replacing the foam, this is what i'd use.
Take a peek inside your spa cabinet...can you add some insulation? We recommend foil-faced bubble-wrap, available at most home improvement stores. It's waterproof, cuts w/ scissors, staples/stuffs in and is R3 per 1/4" (the 'double-bubble' is the best)
There are kits available which are two-part foam. Mixes in the spray nozzle and springs to life. That is what the factory sends me to refoam a tub after any repair or rat damage.
It isn't cheap! I would not be surprised to find that it is available from other sources for less - check it out. The factory part number for a small kit is 70293, does about two or three cubic feet.
There is a much larger kit available -
(http://www.sprayfoamnation.net/files/3442365/uploaded/Sealing-Foam-Kit-1000.jpg)
part number 70869 -which does a huge amount of foam. They list it as eight cubic feet, but I have gotten much more than that out of it.
Be careful with any foam product you use: it can get on your glasses and ruin them, the fumes are bad to breathe, and it MUST be used in warm temperatures only.
HTH
TAP Plastics carry it also.
For you novices Grainger.
