Original => Hot Tub Forum => Topic started by: watzup on November 10, 2013, 01:47:54 pm
Title: Cover maintenance
Post by: watzup on November 10, 2013, 01:47:54 pm
The outside is pretty simple, mild soap/water and a coat of 303.  The inside (bottom) grey material, I usually have to scrub it pretty much to keep the black (mold?) under control.  Was wondering how others keep the inside clean?  Would 303 be ok on the inside after a good cleaning??
Title: Re: Cover maintenance
Post by: rphman on November 10, 2013, 07:39:28 pm
Don't know about 303 underneath?? I use 303 on top and in 6 yrs have never done anything on the underside of my cover and have never had any mold or anything on it.
Post by: wmccall on November 11, 2013, 07:25:00 am
I too suspect that 303, as great as it is, would leave a residual behind on the inside of the cover that would work its way into the water.  I'd never had a mold problem inside the cover, I assume there is enough chlorine gas present to keep it clean, though I try to run the jets awhile before closing it.
Post by: Sam on November 12, 2013, 02:57:54 pm
Get an empty spray bottle and fill it with a 50/50 mixture of distilled white vinegar and water.  Works really well and is environmentally friendly.
Post by: watzup on November 12, 2013, 03:40:19 pm
I'll give that a shot.  Tx
Post by: wmccall on November 12, 2013, 04:11:28 pm
That does sound like a good idea, and the worst case, it may drop his PH a little.
