Original => Hot Tub Forum => Topic started by: 333president on August 28, 2013, 03:44:58 pm
Title: Chemicals/Health
Post by: 333president on August 28, 2013, 03:44:58 pm
Hey Guys,
I just got a Caldera Makena. Pretty happy with it so far.
I am just kind of nervous about all the chemicals. Do they pose a health threat? I plan on using this almost daily. But hate the idea of bathing in chemicals (which I guess is better than bathing in bacteria).
Is it dangerous to be in these chemicals daily?
Is there any natural way/natural products to effectively maintain water quality?
Thanks!
Title: Re: Chemicals/Health
Post by: TwinCitiesHotSpring on August 28, 2013, 04:34:00 pm
essentially the only chemical you would be soaking in a regular basis is Chlorine...and regardless of what people think Chlorine is 100% safe and is used throughout the world for thousands of different uses...disinfection of city water supplies, medical equipment, produce, and also used in hundreds of other industries.  Some good reading here: http://library.thinkquest.org/C004050F/use.htm (http://library.thinkquest.org/C004050F/use.htm)
so to answer your question, yes your spa is 100% safe assuming you keep it sanitized with Chlorine at all times...and no there is nothing that is 100% natural that is strong enough to sanitize a spa to keep it 100% safe from bacteria without using Chlorine, Shock and/or a combination of both
Post by: 333president on August 29, 2013, 02:12:00 am
Thanks so much Twin. I've been using Bromine, but I think it's comparable. Your reply was really comforting and I really appreciate it!
I guess I was also worried about the spa down, metal gone, bright and clear, calcium hardener, etc. It just seems like such a chemical bath!
Thanks for everything.
Post by: Tman122 on August 29, 2013, 07:26:26 am
Spa down is acid and there is the same amount of acid in vinegar. Metal gone grabs a hold of metal and clumps it big enough for your filter to catch it and the agent. Not sure what bright and clear is or if you even need it? And are you sure you need calcium hardener?
