Original => Hot Tub Forum => Topic started by: Tenorscott on June 25, 2013, 07:54:03 pm
Title: 2002 Caldera Tahitian doesn't power up at all! UGH!!!
Post by: Tenorscott on June 25, 2013, 07:54:03 pm
Went to do my quarterly drain and fill on my hot tub when lo and behold, there was no power at all.  I went to the outdoor breaker box and found one of the two breakers was not ON, but the other one was.  Went to the breaker box in the house and saw all was okay there.
WHat could this be.  Yes, it is an older spa but still does the job well...when the power it on...e-mail privately or here.  thank you!
Title: Re: 2002 Caldera Tahitian doesn't power up at all! UGH!!!
Post by: Dr. Spa™ Ret. on June 25, 2013, 10:08:54 pm
Sounds like the breaker tripped.
Post by: Tenorscott on June 26, 2013, 07:24:38 am
I reset the breakers to on both in and out of the house and there is still no power.  Please advise further if possbile...
Post by: Spoiledrotten on June 26, 2013, 07:51:00 am
If you have a volt meter, check and see where the power stops. It might be a warn out breaker, but if you have power through that point, then move on to the panel in the tub to see if you have it coming into the box there. Just work your way down the line.
