Original => Hot Tub Forum => Topic started by: xring600 on May 11, 2013, 05:01:10 pm
I have a waterway insulated wet end pump model number sd-15-2n11cd. The pump is sporadic in operation and I am sure it has almost seen the end of its life. My question can you have the pump rebuilt? It pumps good when operating so its not the wet end but the actual mechanical section of the pump.
You can separate the motor (electric spinner thing) from the pump (wet end) and get either rebuilt, however, in this ady and age getting new ones can be as efficient and possible less costly. How old is the tub? And what brand? You have the seal between the two and the longevity of the wet end to consider. If your going to pull out a motor/seal/pump it may be better to replace them all.
I do rebuild some pumps for people - I have all the pullers and special tools to remove/replace bearings, and a shelf unit full of bearings (actually only two cover most motors), start capacitors and switches. I have done TONS of them.
But having said that, you must keep in mind that if you have a motor rebuilt your money goes into my pocket in the form of labor. If you buy a new motor, your money walks out the door with you in the form of ALL new bits: new winding, new case, new bearings, new electronics, and you may choose to upgrade to a better (more efficient) motor.
Food for thought.
