Original => Hot Tub Forum => Topic started by: brillskill on March 21, 2013, 01:55:53 pm
heres the tub a little less than 3300 delivered curbside plus a 330 dollar store credit at the site i bought it from. the tub i bought is identical just branded differently for internet retailers..http://calspas.com/aqua-select-spas/aqua-select-as730b/
You can't judge value by a web site or a spa delivery or a price. 5 years from now you can see value. And if a 3300 dollar tub last's for 5 years then in the additional years the value will go up. We know you can buy a 8000 dollar tub that will last for 15-20 I've seen it many many times. I paid 3800 for a brand new Great Lakes that lasted for 8 and is still running for it's second owner. It has however had a new pump, heater and control installed at a little over 5. It is getting close to it's end with brittle PVC and wear.
Now the under efficiency of that GL value tub would of cut into any value created by the low cost and the value type of longevity it proved. However I changed the insulation scheme on it to make it maintain the value created by the low price. In Northern Minnesota that was a huge issue. May not be for some value purchasers. The hydrotherapy? Well, I have now had a chance over the years to see what that means. It was a good introduction to the inside of hot tubs for me. Being an on and off tub owner for 20 years and in the plumbing industry for almost 30, value is not in a low price. There are 3 things that contribute to it. Price, longevity and function. Seems like you have the first one conquered but have a ways to go to determine the value of your purchase.
Ty,I just meant on specs alone..I bought a 2k 110 friction heat still working after 10 years :so I know the other variables can only be known with time
Specs mean nothing. They are twisted and turned and written to do one thing. Sell a product.
On first read to me it seems like hundreds of other value tubs. BHP on the pump spec. no clear picture on the R-value of the insulation. An insulated cabinet air space with venting to cool the pump motor???
"Cal Spas is the first in the industry to offer LED jets with individual On/Off functionality - patent pending!"
Not true, LED jets have been around a long time and to say that they have the first jets that turn off and on individually...LOL laughable lies. Waterway created jets that turned off and on individually 25-30 years ago.
I could keep going but my point is the web site and specs used to sell that tub have absolutely nothing to do with the fit, finish, longevity or feel of that tub on the cal spa web site. So it also has nothing to do with the tub you bought.
personally I'd buy a higher end used tub for 3-4k than buy that brand new, just my opinion and what do i know I'm sure one of the "experts" that has been around tubs for 3 months will come in and tell me what I should have said...gl with your purchase
Look at this hotubguy..this I y I won't buy a used tub!
I don't think thats bad advice actually but that also may not work for everyone.
The reality is when you're shopping for spas and you only have $3k to $5k to spend you have to navigate around a lot the cheap junk that is out there because its really hit and miss, especially with all the spas you can blindly get on the intenet and even ebay. Some people are more believers in getting a good used premium spa that has tried and true quality history and there is a lot of merit in that approach so don't dismiss it. Like everything, buying a new budget spa is fine if you make a good chocie.
Ace..u know anything about the geo I bought?..
Personally have never seen a cal spa before. Would I have rather seen you buy a tub from a local guy, yes but it's your money and if you are comfortable with your purchase then that's all that matters. Happy hottubbing! When's it arrive?
I know Cal fairly well but not this model, they tend to have a ton of models and change things a lot so I bet its tough to keep up even if you're a dealer. Good luck to you, hope all works out well and congrats.
Should be here April 2nd
Btw hotubguy I meant the other other guy.the one who bought a used tub with all his problems now
This was one of the most frustrating thing with them. Sure they were always coming out with something different, but we always had to stay on top of parts. One tub of the same series might have something different in it and we wouldn't know it till we went out and looked at it. Then trying to get the right part from them was an issue in itself..
Brillskill quit worrying about what you bought. It will probably be fine, but then again it might not! You won't know till you get it up and running, if you can make it the first month or two without any problems specially right out of the box you will be alright..
not really worried Jim..just making conversation..hoping someone who actually has this specific tub chimes in
Tub coming tomorrow
Buy a used tub..another happy customer..."Very disappointed. I purchased a used California D1, 2003 last summer but couldn't hook it up until now. I very carefully emptied it last fall and covered it. Unfortunately, the cover leaked and I found some frozen water in it, enough to cover the bottom jets. I waited for it to thaw and filled it up. Upon filling, I got a bunch of wood shavings coming out of one of the jets. My electrician had to drill an access hole in the bottom of the base near one of the pumps. I had the pumps disconnected for freeze protection. Probably got in there."....
Again, the key is to view the used spa operating and then bring it home, hook it up and run it. There is NO surprise there is an issue here for someone who bought it, let it sit, water gets in, freezes and then an attempt is made to run it the next year. The SAME thing would have happened if they bought a new spa and did that, the fact it was used was not relevant to the issue that occured.
Well I got my calspa..love it well built and certainly looks and feels like its a more expensive hot tub.. The 2 issues if I have to give the negatives are ..it's hooked to 110 so it took a long time to heat up and yes the jets could be more powerful but if I divert to only half they are great.. All in all I would say you can not find a better plug and play in this price range and I would be comfortable recommending this tub to anyone..if I knew how to upload pics I would
What are you comparing it to based on your experience?
I see u like to start with everyone..comparing it too Watkins rotomold plug and play which retail for about the same..but u r right I am not a spa retailer so my opinion means nothing..
Glad to see your tub found it's way home. Just enjoy your new member.
Thx dog!
Edited to avoid confrontation and negativity
Argue ??..I simply stated my opinion on my particular purchase..professional hot tub salesman ..dare to dream..
I've seen you discuss your search on these pages and I hope all goes well with your purchase. Maybe people are confusing you with Bimmer, I think you just happened upon a crime scene lol.
Ty!
You are correct....there can only be one Bimmerdog. He is a fantastic Yellow Lab
(http://i792.photobucket.com/albums/yy209/bimmerdog/paperboy.jpg)
Lol
Btw how do u upload pics?
I use photobucket.com Once you have the photo downloaded to that site you you can click on that photo and off to the side will be a box with image link options. I then click on IMG code and it will copy that picture and then come back here and just click where you want the picture downloaded. It will look something like this when you paste it on the page phttp://i792.photobucket.com/albums/[/IMG] Then when you post your picture to the site it will show up as a picture
Not to be negative but we looked at a used Cal Spa and talked to the local dealer who had sinced dropped them.Words from the owners mouth-"CalSpa was Horrible-we couldn't wait to get rid of them"
That was 3-4 years ago so hopefully they are putting out a better product now.
I also have known people that have had low dollar spas in rough climates-like New Hampshire that have gotten ten years out of their spas with no major issues-go figure.
Best of luck but that experience scared me away from Cal Spa.
the spa i bought is a very simple model manufacured by calspa..it is replacing a 2k plug and play that i had for 9 years..so far so good ...it came with a defective cover one side where it folds was not stiched right,called cal and in 4 days a new one was at my front door,ive said this before if you are looking for an acrylic 7 ft tub with 110 plug and play option i do not beleive you will find a better value in the 3500 dollar or below range....but i do realize only time will tell....
