Original => Hot Tub Forum => Topic started by: H2O on November 16, 2012, 12:56:49 pm
Hi all.
Iam doing a drain and refill.
I will be useing Metal Gon.Do I wait 24hrs before balancing my water?
Or do I balance as soon as its full.And once its balance then sanitize.
Thank You.
some of it will depend on how "bad" or full of metals your water is but I usually like to give metal gon overnight to do its job (making sure to rinse your filter at least once or twice in the process to remove excess metals) then from there you can begin balancing the water and adding the appropriate amount of sanitizer
