Original => Hot Tub Forum => Topic started by: 1985forever on April 29, 2012, 09:46:33 pm
Title: Cover Cradle II questions for Relay tub
Post by: 1985forever on April 29, 2012, 09:46:33 pm
We are awaiting the Hot Spot Relay.  We got the Cover Cradle II with the spa.  I am wondering if the cover lifter can be installed any way you choose, or does it have to fold away from the control panel?
Where we have it planned, if we open the cover away from the control panel, then we will be blocking a little bit of view.  If we could install it so that it opens towards the "back" of our tub, it will open up against our house and not interfere with any views.
We do have 24" all around.  Just wondering if the fact that the tub is square if the cover lifter orientation can be adjusted to open towards any of the four sides?
Title: Re: Cover Cradle II questions for Relay tub
Post by: hottubnewgirl on September 26, 2014, 04:06:15 pm
Hi,
I'd be interested to know how it worked out.  We are planning on purchasing a Hot Spot Relay and cover cradle tomorrow.  Are you a happy buyer?
Post by: Ron Kleven on September 26, 2014, 07:38:56 pm
There should be no reason you cannot use the Cover Cradle II in any direction.
As long as you can still access the pumps, etc which are under the control on that side of the tub.
If you can get thant panel off it should work.
