Brand Specific Forums => Jacuzzi Hot Tubs => Topic started by: smackman on April 02, 2012, 01:50:41 pm
I understand How the primary filter works. How does the secondary filter work under the polishing bag? I do not understand how flow goes through this secondary filter.
My primary circulation pump is set to run 6 hours a day for the primary filter.
When I set the timer for the secondary filter, the same circulation pump comes on? What pushes flow thru the Secondary filter?
It use to be pump 2 would draw through that filter. Now it is pump one.
You up and running yet?
Negative
Very little flow goes thru the secondary filter; It is almost useless unless I do not understand which is quite possible
It's more for just redundant filtration.
