Original => Hot Tub Forum => Topic started by: heninquins on September 23, 2011, 05:02:48 am
Title: Importance of cleaning Hot tub filter
Post by: heninquins on September 23, 2011, 05:02:48 am
To keep your hot tub working efficiently, a hot tub filter is necessary. The proper filter will make getting into your hot tub a delight, since the water will be clear, clean and inviting. Here are some tips helpful to keep hot tub filter clean and well.
* Check the filter pleats for tears or holes, these allow dirt and debris to go past the filter then it's time for a new filter.
* Avoid laundry detergents and household cleaners. You may have a major foaming problem with your hot tub if you use them.
* Use a product designed for cleaning pleated filter cartridges.
* Rotate spa filters when cleaning, always rotate out filters with a clean, dry spare. With this system you will never have to wait to use your spa, and filters will last longer. Allowing filters to dry completely after cleaning will help destroy any resident microorganisms.
* It is better to replace filters every six to twelve months.
* Never use a power-washer or dishwasher to clean filter cartridges. The high water pressure will damage the media. Be gentle if you use a brush.
* Always follow equipment manufacturer's instructions for removing and reinstalling filter cartridges.
* Ensure that always have the freshest, clearest and cleanest water possible at all times by taking care of your filter and replacing it when necessary.
I hope this information will definitely helpful to someone, thanks!
ADVERTISEMENT DELETED
