Original => Hot Tub Forum => Topic started by: Kaisermust on July 24, 2011, 09:34:53 am
Title: New spa--Do I fill, drain, then refill before using for first time?
Post by: Kaisermust on July 24, 2011, 09:34:53 am
Just got our first spa delivered.  Now before we use it for the first time, do we fill it, run it a few minutes then drain it--to get all the impurities/residual debris from the lines from fabrication at the factory-- and then refill it BEFORE we use it for the first time??? Hubby says he hasn't heard of this and I say yes, I've watched video online telling me it is IMPERATIVE THAT YOU FILL, DRAIN AND REFILL before using.   I want to enjoy our spa ASAP but can wait an extra fill (we have a small 250 gal tub) if that is the best way to go. BTW, we have purchased an eco-one pre-filter for the end of the garden hose from the get-go as we will be filling with well water. Advice for us newbies just getting started would be appreciated. Thanks.
Title: Re: New spa--Do I fill, drain, then refill before using for first time?
Post by: SerjicalStrike on July 25, 2011, 04:29:40 pm
You do not need to fill, drain, and refill.  Just fill it and use it like normal.
Post by: Tman122 on July 25, 2011, 04:49:46 pm
Most of the higher quality brands are fill after manufacturing and then drained. No need to do it again. Just sanitize well during heat up.
Post by: ChaiSTi on July 26, 2011, 06:12:36 pm
Who knows how long the spa sat for in a warehouse.  Spa manufacturers do water test these spas but the water that they use are constantly cycled from spa to spa and saved in a holding cell for future use.  The spas are flipped and the lines are blown out but i'm sure some water remains.
Post by: Chas on July 29, 2011, 01:40:14 pm
I fill and super chlorinate all our new spas - even if they are going to go on Baqua or other non-chlorine system. Of course you have to wait for the chlorine to go away in some cases, but otherwise a simple shock will take care of any 'stuff' which might have remained in the plumbing.
