Original => Hot Tub Forum => Topic started by: Bruce on September 24, 2010, 01:12:49 pm
My hot tub is inside a man cave, and that corner of the room is dim as there are no lights ... other than the hot tub. Where can I buy strings of ready made 12 volt LED lights to hang from above the tub? They can't get hot as there is a thatched roof over it.
Instead of hanging the lights on the thatched roof above the tub you may want to just wrap them around the keg. If you keep the keg close enough to the tub it should provide plenty of light and will make it easier to find the keg.
Search on "Rope Lights" at Amazon or your favorite outlet.... They are 120 VAC tho you may be able to find 12VDC versions for automotive applications. These types of lights, particularly the led versions should dissipate very little heat.
Have fun!
