Original => Hot Tub Forum => Topic started by: Jake on August 26, 2010, 11:00:48 pm
Does anyone have information on the Caldera Palatino spa? It's part of the Caldera Vacanza series. Price range? Does anyone own it?
If you look at them its actually the same as one of the Hot Spring Hot Spots so you may find info on them if you search here.
Thanks Spatech! That was helpful. Hotspot Tempo is the same as the Caldera Palantino. Still not a lot of info out there....assuming they are new models. I'm debating between the Caldera Palatino, HS Grandee and the Sundance Optima at this point.
