Original => Hot Tub Forum => Topic started by: toddyosh on April 22, 2010, 03:43:09 pm
I am looking for a hot tub for my house and have done some research but would like a more unbiased opinion rather than some salesman. I have been looking at multiple manufacturers and different lines. My budget is $6500. I would like to get the larger 6" more room in the hot tub, but don't know if it is really worth the extra $1000.
http://www.hotspothottubs.com/
http://www.marquisspas.com/showroom_everyday_hot_tubs_spas.asp
Please feel free to vote and comment.
THANKS!!!
Neither, Jacuzzi J-280
LOL, I knew someone wouldn't be able to stay on task on this one but that was quick lol.
Hello.
I just purchased the Hot Spot Tempo. The company that makes Hot Spring and Hot Spot (Watkins, I believe) has a very good reputation on this forum and in general.
I wouldn't buy a hot tub from Costco. The best advice I have been given is to make sure that whatever tub you buy is from a reliable dealer. You will most likely have trouble at some point with the tub and want someone who will be there.
Hope this helps!
I think I am going with the Marquis Everyday660. I got a great deal for $5850 for almost everything!!!
Any opinions before I make the leap?
Enjoy it! We love pics.
For what its worth, depending on where you live, you should be able to get a Relay for the same or less, "with almost everything."
I can only offer that my experience with Marquis has been excellent. The warranty, the service and the tub itself. I think you will be pleased with your purchase.
To my knowledge all Marquis were fully foamed so I was surprised to see that the Everyday line of spas are not fully foamed, though it is an option you can chose (see optional features at bottom of linked page below).
http://www.marquisspas.com/pressroom/documents/2010/2010EDHTsalessheet.pdf
I know the reason its built without fully foaming it is to help keep the price down but I'm surprised they build them both ways as IMO it muddies the message a bit. I'd check with the dealer and see if that is already factored into the price so you're comparing apples to apples. I personally would definitely take the option to fully insulate it if it's not already included in your package, it'll cost you more up front but you'll get your money back in energy savings. The other thing I might ask about is the cover; it shows it using a 1 lb density foam core. For larger spas I'd want at least 1.5lb (the higher end Epic is the same size spas but has 2lb) and not just for insulation purposes but also for structure because over time they can sag and 1 lb seems pretty light for larger spas IMO. I'd at least see what my options are.
It is actually the floor model and they said that I cannot add foam. I am a little bummed, but I am getting a $650 discount for no foam. Thanks for the question on the cover; Marquis said the cover uses 2 lb insulation.
Where are you located? If you are in an area that gets "real" winters..you may want to do a little more investigating. You might find your electric costs could end up being more than the discount for the no foam option. :-\
I live in Oregon.
Any other options to insulate it myself?
Personally I wouldn't take a $650 discount for the no foam option because you'll give it back within 1 or 2 years due to higher energy bills, short term gain-long term pain. The website said 1lb density cover, so are they saying that is wrong or are they upgrading yours?
I don't think insulating it yourself is an option. Personally, I don't think I would jump into this deal. Ask to see other covers. Look at the cover an an Epic and see if the two compare. It doesn't even make sense to me to give you the good cover if you don't have foam in the tub. Something isn't quite right. ???
I would stick with the insulated tub, you could get and oput in Rozul insulation it is very good stuff, they use it up in Canada and is used in H2o spas , and they do a real good job, but you might see what kind of deal you can get on one from the factory, since they are right there in Salem Oregon, but my vote would be D1 Dream....had top throw in... but Mrquis is a very good company to work with....good luck
