Original => Hot Tub Forum => Topic started by: gutnick on January 04, 2010, 03:52:20 am
The hose to my Ozone generator appears to be clogged. Has anyone ever had to unclog one? I tried using a long wire, but it doesn't seem to unblock. In the hose, there is a yellowish wax build up. Any idea? Thank you.
Welcome to the forum, I have heard that talked about before, I'm sure one of our more technical users will have some input.
Some of the ozone tubes I've run into have a liner inside that breaks down and will clog. Just replace the tubing, remember to run it with a loop above the water line and install a check valve. Most ozone tubing is 1/4" vinyl.
