Original => Hot Tub Forum => Topic started by: Im-A-Duck on August 31, 2009, 10:47:39 pm
Title: Door Panels
Post by: Im-A-Duck on August 31, 2009, 10:47:39 pm
Does anyone know where I can find the doors for a Caldera Martinique? I have a 2006 and I would like to replace the door panels, the wood glued to the inside of the doors have gotten wet and they are starting to rot. I tried to get the wood off of the panels and punched a hole in one side. That sucker was glued with some kind of gorrila glue. I am also looking for a new cover. I am looking at this site: /www.spacoverbuydirect.com, does anyone know any good or bad about this company? Any advice would be appreciated.
Title: Re: Door Panels
Post by: Dr. Spa™ Ret. on September 01, 2009, 12:41:01 am
They only use a 4mil vapor barrier. They use aluminum C-channel, unknown thickness (steel is stronger and steel of an equal gauge thickness is actually 15% thicker than aluminum). Their bottom material is mesh. The warranty seems good (as far as warranties go). Last time I looked there was no mention of the quality/type of vinyl they use. I do like their adjustable tie downs. Not sure where they come up with their claim of R-24 for their 6x4 cover.......maybe it's for a 4' round cover?
Personally I find their advertising rather deceptive. They talk about using an 8mil vapor barrier, but then during ordering tell you it's 2 layers of 4mil, and want an additional $29. They talk about their great drain and dry underside, but there's a $29 upcharge for that.
Post by: Chas on September 03, 2009, 03:19:11 pm
Ducky,
Have you looked at covers from
www.Rhtubs.com ?
