Original => Hot Tub Forum => Topic started by: Richs100 on January 18, 2009, 01:49:37 pm
Title: Quick Question Re: Hot Spring Filter Door
Post by: Richs100 on January 18, 2009, 01:49:37 pm
Recently, I've noticed that the top half of the filter door (the weir?) on my 06 Envoy floats up and out of the side tracks and then is unable to drop down when I turn on the jets.  Is there supposed to be some kind of a clip or cap on the top of the slides that would prevent this?  I've checked the bottom of the filter compartment for any loose parts, but didn't find anything.
Thanks,
Rich
Title: Re: Quick Question Hot Spring Filter Door
Post by: hottubdan on January 18, 2009, 02:48:01 pm
Thanks,
Rich
There should be two pins, one on each track that prevent this.
Post by: kokanee001 on January 18, 2009, 04:45:28 pm
Yes, the pins are at the top of the tracks on each side to keep the filter door from coming up past the top of the tracks.
Post by: Richs100 on January 18, 2009, 06:31:01 pm
Well I guess they have to be somewhere in the bottom of the filter compartment.  Where else could they have gone, right?
Post by: Gomboman on January 20, 2009, 02:25:42 am
The pins in my Envoy also came out. I never found them for some reason. The HS tech inserted a threaded screw into the top hole to fix mine. It will never come out now.
It should be covered under warranty but you could easily do this yourself if your dealer charges a hefty trip charge. Good luck.....
