Original => Hot Tub Forum => Topic started by: Cdn HockeyPuck on November 14, 2008, 12:26:06 pm
Now that nights have been getting cooler, I've noticed that it is getting colder on my feet coming out of the hot tub and putting the cover on.
I was wondering what people are using , slippers? sandals? crocs? other?
I've tried slippers but they tend to get wet, I'm thinking maybe crocs...
Crocs for both of us, and if its real snowy and icy, we wear them right into the tub and then on the doormat just inside when we go back in the house.
Crocs also
Me too with Crocs.
I use crocs, hubby uses flip flops. be careful on ice with either of them though!
If I have any ice on the ground near my spa, it means I spilled my soda, so I usually just go bare-footed.
However, when it turns cool in the winter I may go for house slippers.
I need new ones - I may have to look into these Crocs I keep hearing about...
8-)
Crocs are great because you can take them off after you get in. Then put them on before you get out so you do not have to step on the cold/icy/snowy ground.
cheap pair of slippers
ditto on the Crocs ;D
Last night was the first soak with snow falling. Wore the crocs, yes they come in size 12, right into the tub. 135 days till the Caribbean.
My crocs froze to the deck last night while the snow was falling >:(
Maybe I will have to try wearing them into the tub as wm does!
Do the chemicals in the hot tub erode the material of the crocs?
If so would it be better to buy knock-offs?
Cdn HockeyPuck, you mention that you have worn slippers between your house and the hot tub. I would be very careful wearing slippers when there is even a hint of ice or snow. I wore slipper once and my butt still hurts. (no traction what so ever).
We now use Crocs. A lot more traction.
