Original => Hot Tub Forum => Topic started by: owltown on July 31, 2008, 04:29:18 pm
Title: test kit question
Post by: owltown on July 31, 2008, 04:29:18 pm
I just got my tub (love it) Hot springs jetsetter (first spa). After reading the forum i noted the suggestion about getting a test kit rather then strips. I purchased a kit I though was correct but when i got it home i noticed one of the tests was different then the strips.
I have an ozonator and a silver ion sanitizer installed. My strips look for MPS, Alkcalinity, and PH.
The test kit check Bromine, PH and Clorine.
QUESTION: Are the tests the same or did i get the wrong test kit.
Easily taken back if so. Any suggestions as to what kit and where to get one.
Title: Re: test kit question
Post by: BauerN on July 31, 2008, 05:45:52 pm
The tests are different.
Bromine and chlorine are sanitizers.
MPS is a shock (non-chlorine oxidizer).
Alkalinity and PH are physical properties of the water.
Which sanitizer are you using?
Post by: Dr. Spa™ Ret. on July 31, 2008, 08:43:28 pm
However, the (scientific) method of testing for chlorine, bromine and MPS are exactly the same (the test measures oxidation potential), although the test results are calibrated differently.
Post by: BauerN on August 01, 2008, 02:02:22 pm
Very cool.   8-)
Thanks for the additional info.  I'm still working on all the ins & outs.
Post by: Tailhooker on August 01, 2008, 11:09:15 pm
Another test kit question here:  I am getting a pool and a spa it seems.  The pool is going to be salt and the pool (likely chlorine), is there a good one stop shop test kit or strip system that will work for both?
