Original => Hot Tub Forum => Topic started by: spalader on June 24, 2008, 08:47:02 pm
Ok, we just had our Marquis Epic delivered with the electrician coming tomorrow. My wife went out and bought pool toys for the kids to use in the hot tub. Should I be worried. Are these things ok in the hot tub?
One toy is 'water bomb balls' - foam type material, filled with polyester fiber and urethane foam material that will soak up water. They are about 5" in diamter. The other is your standard hard plastic creatures, about 4" long, that sink to the bottom and a net to catch them in as they sink. They are meant for pools.
Will these kind of things cause any maintenance headaches? Anyone else have pool toys in their hot tub? Any issues?
IMHO, I think the reason they are called POOL toys is they are for a POOL. I don't have a spa yet, but my two 9 year olds have already been warned, this is not a pool. They will not be diving for dive sticks, floating on floats (unless absolutely neccessary for seating height) or other toys. I would be concerned about intake valves and injuries, with kids jumping around and over each other, etc. They also know we have a pool for that reason--to jump around and play with water toys.
Just my $0.02 worth.
The only "toy" we have allowed in our hot tub are the floating ducks that light up. We didn't want anything getting stuck in the intake valves, or anyone diving for things on the bottom. Now that we've had our hot tub for almost a year, the ducks don't even make it out to the tub anymore....the newness has kind of worn off.
Kids and water and toys are a natural combination. I wouldn't be keen on repressing fun since I'm just a big kid myself.
The water bomb things might end up stuck on an intake and cause a problem, but solid plastic toys probably not.
Just remember to remove ALL toys before changing filters, draining, etc.
I had a duck that squirted water until it broke, I was also warned here about the bacteria it may breed.
I can't speak for others but I don't see a problem with soft water toys, my tub has some large intake screens; as long as you head the advice of take them out before you replace filters.
Goggles & snorkle are probably OK, after all it can be a swirling mysterious place to explore.
No glass, no diving or jumping.
TWO OF THE MOST IMPORTANT ASPECTS - NEVER LEAVE YOUR CHILDREN UNATTENDED & SMALL CHILDREN'S BODIES CAN'T REGULATE HEAT THE WAY ADULTS CAN.
Just remember there is a lot less water in a tub than a pool, using toys may be fun but depending on what they land on (dirt and stuff) they may screw up your water.
my hot tub is a small pool for my family or a big kiddie pool depending on how you look at it. I have no problem with most toys. The kids wanted to bring in water balloons and I told them no. I did not want them to get stuck in the skimmer or the water intakes.
I have no plans on getting a pool so the tub will do my family just fine. The tub in a lot of ways is much more diverse. Last Sunday the weather sucked. Overcast, cool, cloudy. Wound not have swam in a pool but it was perfect HT weather.
When the temps outside are 90's, with close to 100% humidity the last thing I want to do is go into a 100º + tub.
There is nothing more enjoyable than a jump in a pool with the sun beating overhead, temps in the 90's and water temps 84º or so ... and I hate "cold" water OR a soak in 102º water when it's in the 20's ... I haven't soaked in a snowfall yet!
Everyone's different but for me, pools & tubs don't serve the same pupose. 80's water is cold but can be refreshing on hot, muggy days; even on those days there are times that I get too cold because of the breeze I have in my backyard. Any water below 100 in my tub is just not cutting it for a relaxing soak. My wife on the other hand probably could sit in the tub at about 98 or 99 forever; as for the pool she usually waits for the one day the pool water is above 90º. ;D Although she has used the pool 3 or 4 times already!!!
Vinny I don't disagree with you but I don't have plans on getting a pool right now. Given the choice between a HT and pool i would take the HT.
The tub is not refreshing when it is 90 degrees and muggy.
Last time it was like that I sat on a garden chair while the kids were in the tub and I had the hose spraying them with cold water. They had a blast and it was fun for me too.
Spatechs love hot tub toys don't they? They are a prime source of flow problems and easy service calls.
I was always warned to ensure that toys and such should not be able to trap water (squirtguns, rubber ducks with squeakers for example ) as trapped, stagnant water can be a breeding ground for bacteria, espicially so with the hot water in spas.
We make sure to only buy the ducks without the hole in the bottom for that reason. Sometimes hard to find, but they're out there. My favorite duck is a pink one we bought at Linens N Things for breast cancer awareness. The lights in it change just like the lights in our Jacuzzi....pretty cool.
Renee, I have that same duck and looked for more but had no luck. How long ago did you purchase it? I wanted one for the girl that sold me my tub.
Thanks,
Boni
Thanks,
Boni
Boni,
right now there are 60 of them on Ebay. Just do a search for "breast cancer rubber duck"
Good Luck,
Scott ;)
Boni,
Good Luck,
Scott ;)
Ya know, that's the problem in America ... something that's supposed to be for the right reason and the profits hopefully being sent to the correct cause gets twisted for people to make a buck.
It's a shame it's like that.
But hey, people sold the Brooklyn Bridge to unsuspecting people years ago.
I don't think it's just about raising money. It is also about awareness. Pink ribbons always remind people about breast cancer and the need to find a cure. But look at it this way you could buy all the pink rubber duckies and sell them. You could then give the proceeds to the breast cancer people.
I believe that the "first" seller agrees to give a portion of each sale to research..at least that is what the sign said where I got my duck...Probably the EBay seller bought the ducks and Breast Cancer research already got their contribution... :)
"One toy is 'water bomb balls' - foam type material, filled with polyester fiber and urethane foam material that will soak up water. They are about 5" in diamter. "
These toys will come apart after some use and the fiber goes everywhere. I am sure it would wreak havoc in the hot tub circulation system.
We had those foam balls in our pool...always started a fight. They are supposed to be saturated and thrown like water balloons..my kids would start out playing and end up trying to kill each other with those goofy things. I don't even like them in my pool.
Thanks,
Boni
I got that duck last summer, right after we bought the hot tub. Wish I would have bought more too....
EBay has alot of them and the donation has already been paid. So stock-up if you would like.
Scott,
Sorry if you thought my comment was towards you ... it wasn't.
As was said the original ducks on ebay had the profits going to the right cause (assuming that the ducks on ebay were originally purchased). Since it is a hot item the original organization should produce more, make more money, raise more awareness and stop the ebay selling cold. I look at it as me buying pink ribbon, put it into a bow and selling it ... not necessarily for the right reason. Then again I am cynical!
Scott,
Vinny, no worries. My wife and I are hooked on EBay. Anytime I need something I look on EBay. When she said she wanted some pink ducks, you know where I went.
As I have said a few times on this forum, we have my step-dad living with us and he is dying of cancer. He was given 2-4 months to live and that was almost 6 months ago. We have lost several family members, including a 12 year old to cancer. It is a cruel way to die. So any money raised to fight the big "C" is great to me.
Scott :)
