Original => Hot Tub Forum => Topic started by: Saved by Grace on May 14, 2008, 10:21:48 pm
Title: Water has a blue tint????
Post by: Saved by Grace on May 14, 2008, 10:21:48 pm
Our J480 has been running great for a week now. :)  But our water has developed a blue tint.  It is very clear and the readings we get all seem to be in line...the ph is on the low end 7.2 to 7.4.  We are using N2 with daily dichlor and have used stain and scale remover.  My wife thinks it might be dye from my suit.  Any input would be appreciated.
In His Peace,
Fred
Title: Re: Water has a blue tint????
Post by: Jacuzzi Jim on May 14, 2008, 10:31:09 pm
 If your suit is blue,it could very well be that,  add a bit of clarifier see if it goes away??
Post by: Swell-Tub on May 15, 2008, 01:01:12 am
I sure hope your wife didn't put some toilet bowl cleaner in your new tub.  ;D ;D ;D
If your suit is blue, that would be my first guess....
Scott  ;)
Post by: Dr. Spa™ Ret. on May 15, 2008, 01:41:24 am
If you're on well water, I'd suspect copper in the water.
Post by: Steve on May 15, 2008, 01:55:47 am
Silly me... all these years, I thought blue water was a good thing?...  :-/
Post by: benalexe on May 15, 2008, 06:47:30 am
Don't wear a suite and see what happens.  Of course your wife shouldn't either  ;)
Post by: wewannahottub on May 15, 2008, 07:54:55 am
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Post by: windsurfdog on May 15, 2008, 07:58:16 am
Is your tub's shell white?  Mine is and my water, as Steve commented, is always blue-clear unless there are problems.  Or is your water noticeably darker blue than normal?
Post by: drewstar on May 15, 2008, 08:49:27 am
Un pause the light mode .  ;)
Post by: Saved by Grace on May 15, 2008, 12:27:05 pm
It's a beautiful aqua blue...against a white shell.  But it didn't start that way.  It was orange from the well and sat most of a week before we got the tub running.  Then became crystal clear and has very slowly and only slightly/lightly developed a blue tint.  It is not dark blue by any means.  It is a little darker in the shade/at night.  It really is pretty, I'm just not sure if it is normal.
Yes on the well water, how do I test for copper and/or do I need to do anything about that.
Tried the no suits.  ;)
Lights are off.   ;D
And my wife only used the toilet bowl cleaner once.  ;D
Thanks for the input even though I'm still not sure what to do if anything.  I think I'll which suits (my second one is also blue but a different material).
In His Peace,
Fred
Post by: windsurfdog on May 16, 2008, 09:40:16 am
Sounds perfect to me... 8-)
Post by: searchinginfl on May 18, 2008, 10:49:35 am
I asked this question after my first fill. I started out green/brown, and ended clear blue. According to my spa guy, that is the color all spas are. It looks beautiful.
