Original => Hot Tub Forum => Topic started by: RK23 on March 10, 2008, 09:27:15 am
Title: Caldera light issue
Post by: RK23 on March 10, 2008, 09:27:15 am
Hi Folks,
I've owned a 2007 Caldera Niagara for 5 months.  This tub has the spa glo feature that rotates colors, but also allows you to stop on any color.  I have used this feature many times, but over the past week i have not been able to unlock the set color and get back to rotating (the combination of buttons to press to do this is the light/set buttons simultaneously).  Each button works independently, but in combination the trigger to go back to rotation no longer works.
Does anyone have any ideas as to anything else I can try?  I will put a call into my dealer today, but was curious if anyone was aware of a quick fix or if this is a common issue.
Thanks,
Russ
Title: Re: Caldera light issue
Post by: H823Putt on March 10, 2008, 09:34:12 am
I have a Caldera Aspire and had a different problem. When my lights would rotate through the colors, it would get stuck on a color for a while then skip over others. My dealer sent out a tech and it was a quick 5 minute fix. I say call you dealer.
Post by: RK23 on March 10, 2008, 10:04:14 am
Thanks H823Putt.  I have a call into my dealer and will let you know how I make out...
