Original => Hot Tub Forum => Topic started by: IlliniFan on November 04, 2007, 09:33:14 pm
Title: F settings for jacuzzi in cold weather
Post by: IlliniFan on November 04, 2007, 09:33:14 pm
What  F settings do you use in cold weather?  Do you vary them depending on temperature outside?   Thanks for your help.
Title: Re: F settings for jacuzzi in cold weather
Post by: Chad on November 05, 2007, 06:09:53 am
Good question.
Last winter was my first with a spa. I kept it set for F3 because I have the mindset that more is better. Then this past spring I experimented with less programmed cycles and there was no change to my water quality. I guess our 24 hr circ pumps do a pretty good job by themselves. So I have been keeping it on F1 ever since. I even noticed a decrease on my electric bill. I think the key is to set it for the lowest amount possibly w/o effecting your water quality.
I might set it back up to F2 or F3 if I start noticing that when I go out to soak, my water is constantly below my set temp.
Post by: spa-ing on November 05, 2007, 12:17:32 pm
Whatever keeps it at 101 degrees.  I'm in the Chicago area as well.  We never use it when it is windy however.
