Original => Hot Tub Forum => Topic started by: Chris_H on July 05, 2007, 11:49:42 am
It is the middle of the year so I thought I would bring some attention to this topic. ETL is a testing company that tests spas to make sure they follow certain guidelines. I would recommend any future purchaser to verify their spa and manufacturer is ETL listed. This is for the safety of the actual users of your hottub. For potential customers, if the spa isn’t listed I would think again on purchasing that brand of hottubs.
Here is where you can search for your ETL listing:
http://etlwhidirectory.etlsemko.com/WebClients/ITS/DLP/products.nsf/$$Search?OpenForm
If you find out that someone is stating their spas are ETL listed, but cannot find that manufacturer or brand, you can even request a field investigation. Here is where you can find this:
http://www.intertek-etlsemko.com/portal/page/cust_portal/ITK_PGR/DOCUMENTS_PROD_PG/Field_Investigation_Request.pdf
Chris
I have an '05 Marquis Reward and it's listed with UL.
Phil
http://etlwhidirectory.etlsemko.com/WebClients/ITS/DLP/products.nsf/$$Search?OpenForm[/url]
ETL (Electronic Testing Laboratories?) is one of the test organizations that covers spas; another is UL (Underwriters Laboratories). CSA (Canadian Standards Association) I believe may cover some of the electronic components used in spas. TUV is the standard in Europe. There are many more.
Please do search with some care. If you were to look for Arctic Spas, for example, you'd find no results. What?!! Aren't they ETL listed? >:(
Ah, but wait! A search for Blue Falls Manufacturing, the parent company to the brand, turned up the various ETL listings for Arctic Spas and Coyote Spas and other products. :)
You can also check for TUV (European certification for exported spas). There are numerous TUV testers and sites; our certificates are logged at http://www.tuev-sued.de/ TUV SUD . I was able to find them easily with the Certificate Explorer - but if you were searching a different TUV organization, you might miss them -- and again, search for Blue Falls Manufacturing.
ETL= Edison Testing Labs.
Thanks Tom. I should have mentioned that there are other testing facilities, as I knew that.
Are there spas being sold that have not submitted samples to a recognized testing orginazation? Other than the re-brander, I mean.
I mean electricity and water- could be a disaster in the making. I'd think some form of widely recognized and independent testing would be in order to protect themselves.
The Coleman line up is ETL approved.....very nice
