Recent Posts
Pages: 1 [2] 3 4 ... 10
11
Show us your Hot Tub. / Re: My Aetesian Island Nevis has arrived!
« Last post by Patrick Bailey on March 15, 2024, 05:33:40 am »
Nice, that's awesome! Perfect for some serious relaxation.
12
Hot Tub Forum / Re: Repacement Jets for 2002 Cameo - Differ Style
« Last post by Ellen Gallagher on March 15, 2024, 05:27:47 am »
 Sounds like you're knee-deep in spa maintenance! If the replacement jets aren't staying in place, it might be worth looking into different styles that could fit your Sundance Cameo. Sometimes, certain styles just work better with specific models.
Have you checked with a local spa dealer or searched online for compatible jet options? They might have some advice or alternative styles that could solve your jet troubles.
13
Hey Dave, it's great that you're researching so thoroughly before making your hot tub purchase! It sounds like you've found a new dealer with some tempting discounts, but you're also considering the value of experience and service from a more established dealer. Since a dealer's service team can be crucial, especially for warranty support, it might be worth paying a bit extra for that peace of mind.
If the larger dealer can match or come close to the new dealer's price, that could be a good compromise. Ultimately, the decision depends on how much you value the potential for better service over the savings.
14
Hot Tub Forum / Re: Struggling with pH Levels in Small Inflatable Hot Tub
« Last post by Sean Lawrence on March 15, 2024, 03:46:40 am »
Dealing with pH levels in hot tubs can be such a pain! It sounds like you're doing all the right things by testing and adding chemicals, but sometimes those levels just don't want to budge. Have you tried using a different pH decrease or maybe adjusting the water flow somehow to help with mixing? It's frustrating when you feel like you're throwing everything at it and nothing's working. Hang in there, hopefully, someone here has some advice that can help you out!
15
Hot Tub Forum / Re: chlorine
« Last post by Sean Lawrence on March 15, 2024, 03:45:05 am »
Sorry to hear about your skin troubles with the chlorine. It sounds super annoying. If the conditioner didn't help, bromine could be worth a shot. It's gentler on the skin for some folks. Just make sure to read up on how to use it properly since it behaves a bit differently than chlorine. Good luck, hope it sorts out your itchiness!
16
Taking the tub back to the showroom for an electrical issue? That doesn't sound right. As long as the tech has access to all sides, it should be able to be repaired at your home.
17
I am still waiting to hear back from the dealer. The repair guy said that if it was an electrical issue they would have to take my tub back to their showroom to repair it. Anyone else know if that rings true?
18
Hot Spring Spas / Re: Freshwater Salt Cartridge Lifespan Experiences
« Last post by gwmac on March 14, 2024, 07:56:52 am »
I have had very good luck. I don't add any chemicals at all other than the ones my dealer gave me for things like adjusting calcium or Ph levels. My last 2 salt cartridges each gave me over 6 months. They will start gibing you warning to replace them at 4 months but I just chose to ignore those messages and the cartridges were still fine. When they finally go bad it will give you a message that you need to replace them
19
Hot Spring Spas / Re: Freshwater Salt System - Can it be disabled?
« Last post by gwmac on March 14, 2024, 07:51:07 am »
Yes, just slick on the saltwater settings where you can adjust the levels of salt from 1 to 10. Select 0 and it will turn it off completely.
20
Bullfrog Spas / Re: NeckPlus Vs. NeckEase (2023)
« Last post by Sean Lawrence on March 13, 2024, 10:39:05 pm »
I've got the NeckEase JetPak and it's been awesome for me. Can't compare to the NeckPlus, but the NeckEase feels strong enough, especially if you only got two JetPaks. Haven't had any issues with water spraying out where it shouldn't, but I guess it depends on how you position yourself. As for the back, the DeepRelief JetPak is my go-to for some serious relaxation. Your A6L sounds like it's gonna be a dream with all those packs! Enjoy it when it arrives!
Copyright ©1998-2024, Whats The Best, Inc. All rights reserved. Site by Take 42
