Original => Hot Tub Forum => Topic started by: Buckshot1979 on February 10, 2015, 10:12:42 am
It is 5-6 person with a lounger, Balboa VS 501Z Spa Pack(2009), can't find any numbers stamped anywhere to I.D. the Make and Model. It measures 78" x 84" I have attached some photos of the hot tub via photo bucket. Is there someone that can help.ß
http://s292.photobucket.com/user/Corey_Brewer/library/
Thanks Corey
Get inside the equipment bay and see what it says.
Thanks for replying but i looked under everywhere, if it was there once they spray insulated everything
If the spa pac was replaced a time or 2 it can be hard sometimes. What specifically are you looking for? Besides the brand? There is no warranty and it is likely generic waterway jets, manifolds valves and stuff. There should be ID on the motors. Ya got the control PN.
Does it work?
found a Serial number sticker on wood frame it was sprayed over with foam it said Serial NO : 15138
that was all the sticker said, Im looking for a 3" diverter cap, for my (3-way), just the cap, and would just also like to know the Make, Theres no warranty here…lol
It has three motors all Aqua flo #1 Circ-master HP
HP 1/15
#2 flo-master XP2e #3 flo-master XP2e
HP 2.5 HP 5 2speed
Knowing what the motors/pumps are, is like trying to identify a car by the make of the tires.
Do you have access to Waterway? They sell all the plumbing parts? Can you use a common size cap?
