Brand Specific Forums => Hot Spring Spas => Topic started by: dsandonato on November 12, 2019, 04:43:00 pm
I understand that after adjusting the salt output level, you must hit the Confirm or OK button. I hit the OK on the screen but it goes back to a setting of 1. (it previously was going back to 3) From the manual, it describes that the level is automatically lowered after Day 15 then 20. How do I get my setting to stay? Thanks... otherwise, the spa has been great!
Turn the power off to the spa, leave off for a minute or so and then turn back on. If that doesn't fix it, you probably have a bad controller (power supply) for the salt system. That is what I was told by Hot Spring tech support when this happened to one of my customers. Power off/on solved the issue for me.
Thanks for the recommendation. As luck would have it, when I went out to check the spa after posting my question, and there was a screen that I hadn't seen before asking for confirmation. So I confirmed and it has retained the setting. Its day 20 so hopefully my problem has been solve.
