Original => Hot Tub Forum => Topic started by: Calypso on June 12, 2008, 12:03:25 am
Just checking to see if anybody has somewhat locked into a fixed routine in their tub.
I start out in the calypso seat that has the vibrating massage jets no air to loosen up, then same seat with air sitting up to do toes to shoulders, then slide forward slightly for ultimate neck/shoulder massage. On to next main seat which has dual air controls and a large lower back jet and rotating dual shoulders jets plus hip calf and feet jets. I crank the air everywhere and then turn off the lower body air and slide slighly forward to get another great neck/shoulder massage. Last seat is the therapy seat and I crank the air and move up and down to remove any knots that are still there. Routine is 20 minutes and with some stetching makes my old body feel like a kid again
Do you do the same and do you have to readjust the jets because the love of your life has moved/adjusted jets :)
Photobucket test below: wife still loves the tub as much as the expression on her face shows
Let me know what your routines are.
PS help!! How do i get images from photobucket to here. i must be doing something wrong
"How do i get images from photobucket to here. i must be doing something wrong"[/i]
when you go to make a post hit the icon in the tool bars that looks like this: (http://www.whatsthebest-hottub.com/yabbfiles/Templates/Forum/default/img.gif)
after you click the icon two sets of brackets will appear
copy and paste the PhotoBucket direct link url of the picture between the brackets
hit "preview" to make sure you have done it correctly
if all looks well, hit POST
