Original => Hot Tub Forum => Topic started by: StevoDevo on April 12, 2021, 08:14:59 pm
I have a South Seas spa and one of the pumps just started leaking. Do I need to replace the pump or is there a way I can get this repaired?
https://i.imgur.com/Y8VtCyQ.jpg
https://youtube.com/shorts/h6leIY6y37g?feature=share
Your shaft seal isn't where it should be, that's the black ring that is in the middle. You can get a kit to fix it.
I can't read the motor data in the picture. Either spadepot.com or hottuboutpost.com will probably have what you need.
