Brand Specific Forums => Marquis Hot Tubs => Topic started by: Jennsmith on August 11, 2019, 08:29:03 am
Hello
I have a Marquis Reward 2012 tub. The bottom buttons on the Bathers Control Panel are not working. The top ones do. The temp buttons work. There are no codes on the screen and the tub heats. Any thoughts or should I buy a new Control Panel?
Thanks.
Hello
Thanks.
Maybe your dealer has a spare control panel they can let you plug in to try?
It could be in lock mode, but typically if it’s locked it wouldn’t allow you to adjust the temperature. Lock setting usually makes it so you can only turn on the jets and the light, but no other buttons will work.
