Brand Specific Forums => Bullfrog Spas => Topic started by: Wakefield2020 on May 11, 2020, 09:38:04 am
I've seen the cost of an A7 or A7L anywhere fWrom $10,500 to $12,500. What should I expect to pay?
i landed around 9300 for an a7 after some negotiating and lots of homework across local dealers and multiple brands.
geez that is crazy low - was that this year? i had been quoted 11,700
9300???? That's crazy. Did that include anything? I just got an A7L for 10,800 with EOS3, Circulation Pump, cover, lifter and steps and delivery and installation.
Even that is a very low price
hi....Canadian here...do we really need the EOS3 and circulation pump? my dealer is saying not worth the upgrade and it will work just fine without then....also I was quoted 13000 CAD with everything but not tax. is that a good deal? thanks for your help
the eos 3 and circ pump will help you use fewer chemicals but the main advantage of the circ pump is that it's quiet. Without the curc pump it will use the main pump and jets to circulate water through your filter. Mine is near a window so that was important, if yours is away from your house then you may not care.
thank you - can i add this later on in my hot tub? like 1 year down the road? the hot tub will be beside my kitchen window. thanks.
I would check with the dealer on that. I wanted a stereo on a floor unit and he said it needed to be factory installed. Eos and circ pump are different but eos especially looks a bit involved. I'm having both those options installed btw...
