Brand Specific Forums => Bullfrog Spas => Topic started by: kingdarb on July 26, 2015, 08:48:45 pm
Hey folks. I am thinking of adding a Del Spa ozonator to my bullfrog R6 tub. I am likely going to install it myself. I have to modify my deck a little bit to create access to the control panel, so I have not been able to open it up to see what type of plug the ozonator needs to connect to. I am hoping to order an ozonator so that the install can coincide with my next drain/refill as well as the day that I modify the deck an install a trap door. So I was hoping that someone might know the answer as to what type of plug I would order on the ozonator (four prong/two prong/j&j,etc...) so that I can more or less do everything at once.
Thanks in advance!!
If you have a Balboa circuit board, it is likely that you need a Amp 4 connector.
Hey thanks for the reply. It is a Balboa board.
No prob, hope it helps!
