Brand Specific Forums => Hot Spring Spas => Topic started by: cburk0677 on April 19, 2011, 09:11:46 pm
I went out to check the water on my 2006 Vanguard tonight and the water was only 85 degrees. I had the temp set at 99. I tried raising the temp to 104 on the control panel and did not hear the normal click that I do when the heater clicks on. The power light on the outside of the tub is solid red. All of the jets function just fine and the circulation pump is running with ozone bubbles just like normal. I shut off power to the tub for about a minute and then turned it back on. Everything but the heater is working fine. I have a call in to my local hotspring dealer but I was wondering if there is anything else I should check before they come out.
My guess would be the "Heater Relay Board."
If you want, you could open the front of the spa, then open the front of the "IQ-2020" and look at the smaller of the two circuit boards - specifically the one on the left to which the incoming power attaches.
If there are any signs of burning between the squarish relays, you know what the problem is.
Also, take your finger and wipe along the bottom interior of the IQ-2020 box. If there is a fine gray dust which your finger can pick up, you have confirmed the problem.
Depending upon your delivery date, this may still be under the five year warranty, assuming you are the first owner...
