Original => Hot Tub Forum => Topic started by: BobbyM on December 03, 2023, 11:10:58 am
Title: Favorite spa vacuum?
Post by: BobbyM on December 03, 2023, 11:10:58 am
Do you have a favorite spa vacuum? In general, do the siphon models work, or is it important to have power?
In case spa size matters, I have a Sundance Claremont (six seats, about 400 gallons). Also, this tub has several overhead trees, so leaves of all sizes often land in the water.
Thanks for sharing any opinions from your experience.
Bobby
Title: Re: Favorite spa vacuum?
Post by: CanadianSpaTech on December 04, 2023, 07:45:29 am
Quick Drain. Can be used to vacuum up debris and also to drain. No power needed.
Post by: Ripper238 on December 04, 2023, 12:12:08 pm
I generally like using a clear hose and the siphoning method.
Post by: Davekro on December 19, 2023, 05:13:58 pm
I like the clear hose idea! What hose ID size do you use? Do you have anything attached to the siphon end to widen its intake area some?
Post by: Raymond Enriquez on March 28, 2024, 03:36:27 am
We have the same method.
