Brand Specific Forums => Bullfrog Spas => Topic started by: socal147 on February 24, 2011, 09:47:53 pm
Decided on the BullFrog 231. I wanted a smaller spa that was built well. It seemed that all of the others I looked at were built the same way. The biggest difference seemed to be in name alone. I like the fact that the BullFrogs dont use wood in the construction. That may or may not be an issue.
I will recieve the spa in about two to three weeks. I will post my experience as honestly as I can.
Patrick
P.S. I will post pics of the install and such. ;D
Sounds like you found a tub you like - enjoy!
Congratulations! :) Welcome to Spa-topia :D
We will look forward to hearing about it.
(http://www.bullfrogspas.com/images09/spas/231Top.jpg)
This is where the BullFrog will be sitting. I finished the privacy fence today and the 220 is ready and waiting. I still need to complete some landscaping and such. Privacy still needs to be improved. ::)
Got the raised bed built. Planted some Olive trees and Golden Broom. The raised bed will have the four Climbing Jasmines and other plants yet to be decided. I am hoping this will make the spa area both a private and enjoyable area to soak.
I took a water sample into work today and got these results:
Hardness: Ca = 96
Total = 104
Other = 8 [originally posted as Mg. This may not be the correct constituant, but the value is correct.]
Alalinity: p = neg
m = 80
ph: 8.12
I definitely commend you for your preparation. Have a delivery date yet?
I was informed today that it is built and should be here next Friday. :D
Oh well the delivery was a little late. No fault of BullFrog. The shipper decided to ship from LA at their leisure. Now it is time to enjoy. I have included photos of the equipment compartment and wiring. The hardest part was trying to move the 6 gauge wires into the terminal strip. Chemistry was easy to get into spec and my GFI test went perfect. 96 degrees now. Set for 100. Cant wait! The Cover Caddy works fine so far.
congrats Socal, that is a sharp looking little tub, enjoy it for many years ;D
Thanks.
Report to date; I am very happy. The size is perfect and I really like being able to switch up the Jet Packs. I have already done this on the lounger. I do love to relax in my BullFrog. ;D
Chemistry is kind of finicky due to the small water capacity. After receiving and using the Taylor 2006 kit, chemistry was a lot easier to get perfecto.
