Original => Hot Tub Forum => Topic started by: Gibson00 on November 22, 2021, 05:21:37 pm
Hi all, just took delivery of our new Arctic Spa. I'm a bit rusty on taking care of the water quality.
I plan to do dichlor to bleach method, and pretty comfy with how that works.
I have a taylor kit, but just starting off trying to get things with test strips.
Please see the attached pics.
For the test strip pic:
top row is ph
next is free chlorine
next is alkalinity
next is stabilizer
We threw a full cap of boost powder in to shock, so thus the high chlorine.
For the top row, I assume I need to add some ph down?
Alkalinity looks about OK?
I can't remember what stabilizer is!
The chemicals I have are:
ArcticPure Adjust Up
ArcticPure Boost
ArcticPure Refresh
ArcticPure Adjust Down
https://ibb.co/d0wDZxX
https://ibb.co/SvGZLBh
Please advise one what I should use. Thanks!!!
Oh, I also have a bottle of ArcticPure Perfect Balance, which I see is for the Alkalinity...
But still not sure what the low stabilizer reading is pointing to or what to do about it
EDIT - OK, is the stabilizer CYA? And will that just come up on its own after the chlorine starts working?
Dichlor has CYA in it so yea........Cyunaric acid (spelling) When it gets high enough switch to bleach.
Thanks. Yup, I think I have the dichlor to bleach schedule ready. I just couldn't remember if I needed to do anything right away to raise the 'stabilizer' level showing on the test strip. But I guess that will come up on its own after a few doses of chlorine and CYA starts to climb.
I switch from dichlor to bleach when the CYA hits 50ppm and when it drops to 30 I switch back to dichlor. This method
has worked for me for many years.
I find 1/3 cup of household bleach = 1 tablespoon of dichlor.
