Original => Hot Tub Forum => Topic started by: kluzo on April 04, 2008, 01:39:26 pm
a good at least 6-7 months from the last water change. Is there any thing extra that should be done while doing the water change? No chemicals have been added in about 1-2 months. I will be putting in a new filter but I have not yet seen the condition of the current one. I assume it is toast.
It has been about 4-5 months the last time it was used. :(
Depending on age of filter, it could be cleaned with a cleaner/degreaser.
You might want to use a pipe cleaning product like Spa Purge or Swirl Away.
Swirl away is good product but I'd also shock the liv'n B Jesus out of it prior to dumping or with the fresh fill before using it. :P
I'd also put the filter in bleach for 10-15 minutes and then rinse it off. Use your regular filter cleaner after that if indeed it's salvagable. Once you look at it, you may just decide to chuck it...
