Original => Hot Tub Forum => Topic started by: MikeK157 on February 09, 2022, 06:11:30 am
Looks like either my heater blew or something else broke. Should i drain the hot tub asap? Water inside is already cold
If the temp is going to go below freezing yes drain. But you also have to winterize your tub
to insure no water gets left where it will cause freeze problems.
Ty. Called a couple repair guys. Getting minus 30 temp on the weekend
