Author Topic: New job  (Read 25441 times)
New job
« on: August 13, 2005, 06:09:06 pm »
I'm starting a new job Monday.  In the last job I think I spent more time moderating this forum than I did what I was being paid for.  I'll try to check in during the work day periodically, but it won't be as much as recently
New job
JcDenton
  • Be Cool or be cast out
Re: New job
« Reply #1 on: August 13, 2005, 06:14:54 pm »
Best of luck in your new position Bill.  :)
Jc
Re: New job
« Reply #2 on: August 13, 2005, 07:44:11 pm »
Exactly what IS your new position, and why were we not asked to give references?
Lori
Re: New job
« Reply #3 on: August 13, 2005, 08:01:34 pm »
Congratulations!  I wish you much success in your new position!!!
autoplay
Re: New job
« Reply #4 on: August 13, 2005, 08:32:49 pm »
I'll bet he's the new chicken wing inspector/taster for the entire state of Ohio  ::)
Re: New job
« Reply #5 on: August 13, 2005, 09:18:39 pm »
I wish!  I gave up my position as an underpaid one man IT Dept/Network Administrator for a position as a Field Engineer for a local PCSupport company that specializes in PC  service for small companies and individuals with  a lot of money.
Lori
Re: New job
« Reply #6 on: August 14, 2005, 10:14:33 am »
I think that sounds fantastic, Bill!  I know a change will be great for you.
Re: New job
« Reply #7 on: August 14, 2005, 02:08:00 pm »
Good Luck with your new job!!
Re: New job
« Reply #8 on: August 15, 2005, 09:03:12 am »
Thanks  Vinny and all.  I just found out the Bluejackets are one of our customers, so I have that to look forward to.   Maybe a couple of hot tub dealers might be too. We will see.
Re: New job
« Reply #9 on: August 15, 2005, 10:55:38 am »
All the best - here it is Monday already!
Go get 'em Bill!
And don't write your name on your tools. That way if you leave one inside an expensive computer they won't trace it back to you.
We did the same back when I was an aircraft mechanic...
Re: New job
« Reply #10 on: August 15, 2005, 10:55:59 am »
We promise to behave and not post anything controversial since you can't pop in so often.   ;)
Re: New job
« Reply #11 on: August 15, 2005, 12:22:51 pm »
NOT !!
stuart
Re: New job
« Reply #12 on: August 15, 2005, 12:48:22 pm »
Yeah right...Sure we will...just um, set back and don't look OK!
BTW, good luck with the new job and congrats...I'm not around here much anymore so you already have much less damage control to do!! ;D ;D 8) 8)
« Last Edit: August 15, 2005, 12:49:48 pm by stuart »
Re: New job
