Author Topic: SoothingStream running slow  (Read 2450 times)
geekd
  • 2006 HS Grandee
« on: October 03, 2006, 01:17:54 am »
Hey all.  I did a search, but I didn't find anything.
Tonight I notice the SoothingStream water feature in my 2006 HS Grandee was running slow.  It used to "overflow it's banks" when I turned it all the way up (or even halfway), but tonight it was running pretty low.
Yesterday I cleaned the filters (Tri-X).  Could I have put them back in wrong?  Is there and "upside down" to the Tri-X?
The jets seemed at their usual power tonight.
Thanks in advance for any help.
-geekd
hottub.pool_boy
Re: SoothingStream running slow
« Reply #1 on: October 03, 2006, 08:19:17 am »
The only filter that could affect it is the one over the grey standpipe. Try that first. You may need to have a tech out to replace/ or check the valve.
geekd
  • 2006 HS Grandee
« Reply #2 on: October 04, 2006, 09:24:04 pm »
Thanks, hottub.pool_boy.
When I remove the filter from the gray standpipe, and the Everfresh thing, the water flow in the stream is still slow.
I'm not real concerned with that.  My concern is this:
I know the pump that powers the Soothing Stream is the circulation pump.  This is the pump that continuously filters my water, right?  Is this a sign that my circ pump is clogged or otherwise flow-impaired?
The ozonator bubbles seem the same.  The jets seem just as strong.
Thanks,
geekd
hottub.pool_boy
« Reply #3 on: October 05, 2006, 08:02:13 am »
If you have ozone, the circ. pump is fine. Sounds like a problem with the waterfall valve.
