Author Topic: The Truth About Ozonators in Spas  (Read 19947 times)
Gary
« on: July 28, 2006, 03:26:26 pm »
Ozonators are worthless unless the spa is built correctly to use the ozone (most do not build the spa properly). The spa has to have a contact chamber or it will be useless. I am amazed how many ozonators are sold/installed on spas without a contact chamber.
Done properly they are a big help and if you have one of these spas if the ozonaotor fails you will know as your water quality will diminish fairly quick.
If a dealer or manufacturer is selling/installing ozonators without an contact chamber they are crooks or stupid. Either way you are being stroked!
Gary
Re: The Truth About Ozonators in Spas
« Reply #1 on: July 28, 2006, 03:28:58 pm »
Gary
What spas have a contact chamber? Which do not?
Gary
« Reply #2 on: July 28, 2006, 03:39:42 pm »
Vinny's does not ;D
The two that I know for sure are:
Marquis & Hot Springs
I am sure there are few more but not many.
« Reply #3 on: July 28, 2006, 03:43:16 pm »
My Tiger River did not have 03 standard (unike thier Hotsprings Sisters who have 03 standard). The dealer installed the system for me and   I was lead to belive that there was a contact chamber,  how can I verify this? Under the cabinet it looked like the FWIII system hooked directly into the circ pump line.
What consititues a contact chamber?
« Last Edit: July 28, 2006, 03:45:13 pm by drewstar »
cooltoy2000
  • Go Flames Go!!!
« Reply #4 on: July 28, 2006, 03:43:25 pm »
Vinny's does not ;D
So does D1.
« Last Edit: July 28, 2006, 03:44:09 pm by cooltoy2000 »
uncommonlytasty
  • I love my cheep spa
« Reply #5 on: July 28, 2006, 03:48:04 pm »
My Hydro Spa Omni has about 20+ feet of hose after the venturi (where the ozone enters the water).  This allows for more contact time before the gas is released into the air.  As I understand it, the amount of ozone released into the air under the cover is reduced with longer water contact time.  This reduces ozone buildup that can cause covers and pillows to deteriorate.   I don’t know if this is fact, but it makes sense to me.
Vanguard
« Reply #6 on: July 28, 2006, 03:54:17 pm »
All Watkins Manufacturing spas have contact chambers:
Hot Spring
Tiger River
Hot Spot
Solana
Caldera
Gary
« Reply #7 on: July 28, 2006, 03:56:43 pm »
You would have to do some digging. All it is a extra piping so the ozone can stay in the water longer. The spa would also have to a injector to create the venturi affect (most are Mazzies). No injector = no contact chamber.
sledjunkie
« Reply #8 on: July 28, 2006, 04:01:53 pm »
Vinny, are you sure your tub has a UV and not a CD Ozonator?
My artesian(05) has a mazzie injector and has a CD(not UV) ozonator.
JeffB
« Reply #9 on: July 28, 2006, 04:05:27 pm »
On the Artesian Island spas, standard ozone and Propure ozone are options. It is my understanding that standard ozone does not include a contact chamber and Propure ozone does. I recently bought a 2005 Captiva and was told and believe it has the Propure ozone.   Jeff
« Reply #10 on: July 28, 2006, 04:41:23 pm »
It does. I'm holding up my right hand as I type. (That's why it took so long).
The contact chamber is a length of pvc flex pipe - which has a gentle spiral built in - and is between 12 and 14 feet in length. It is wrapped around the footwell area, covered in insulating foam.
You can't see it, but it's there.
hymbaw
« Reply #11 on: July 28, 2006, 04:41:29 pm »
All Sundance tubs are equipped with a Mazzei injector and a contact chamber.
In Canada eh
« Reply #12 on: July 28, 2006, 04:43:45 pm »
Gary
The tub is your contact chamber just the same as a resevoir is the contact chamber at a water treatment plant.  Well we are clearing up misconceptions UV is not ozone and has no oxidizing characteristics at all, it is only a secondary treatment
Bullfrog 451
« Reply #13 on: July 28, 2006, 04:44:43 pm »
HotSpring tubs have the contact chambers, Tiger River have them even though they do not come standard with the ozone generator, Caldera has it, etc.
No injector does NOT mean that the spa is not 'ozone ready.'
« Reply #14 on: July 28, 2006, 04:47:29 pm »
Um, no.
There is a contact chamber in many top-brand tubs, designed to allow the ozone and water to stay in contact for  a few critical seconds BEFORE the mix is injected into the tub. If the tub was the contact chamber - and I have sold other brands where there is no contact chamber - the ozone smells, burns the cover, pillows and doesn't work as well.
