Author Topic: 1st water change question  (Read 4313 times)
newtotubbing
  • Lovin' my Vista
« on: December 04, 2004, 04:50:03 pm »
I have drained the tub today, wiped it down, spa glossed the upper half and it is refilling right now with hot water.
How soon can I get in the tub if the temp is ok?  My book says to add dichlor and wait overnight.
The tub will be plenty hot tonight and I want to use it.
Should I add the dichlor and wait until tomorrow?  Or add the dichlor after I use the spa?
Advise appreciated.
Jonathan
stuart
Re: 1st water change question
« Reply #1 on: December 04, 2004, 05:07:57 pm »
I would add less chlorine, run the jets with the cover open awhile and use it about an hour later.
UnderTheStars
« Reply #2 on: December 04, 2004, 05:16:16 pm »
Just a rookie opinion, but if I were filling a tub that just got delivered (or has been sitting idle) I'd superchlorinate before using (water has been sitting in pipes.)  But if you've been using the spa & properly treating it, you should be ok to use it first then do the superchlorinate.
I agree with Stuart about having a low level of chlorine in there.  For my 400 gallon tub I'd put in 1/4 tsp & climb right in or 1/2 tsp and wait an hour (but I use chlorine & minerals.)  If someone climbing in with you brings something unwanted (say athlete's foot?) I'd like to have a little dichlor in the mix!
Stars
windsurfdog
« Reply #3 on: December 04, 2004, 06:49:03 pm »
Way to go, Jonathan!  How 'bout that new water?  Great, huh?
I think bubba stu and UTS hit the nail on the head--the only thing I would do differently than UTS is to bring the chlorine level up between 3-5 ppm which, for your tub, is between 2-3 tsp.
Happy Spalidays! 8)
newtotubbing
  • Lovin' my Vista
« Reply #4 on: December 04, 2004, 07:02:49 pm »
I thought that my water was clear before but it is now totally crystal clear!  What a huge difference, it looks less, how do you say, thick?  Yeah the water thicker before the change.  Is that a good description?
I added 2 tsp of Spa Gaurd Enhanced Shock and ran it for 20 minutes with the cover open.
Now just waiting for it to hit 101!
Thanks.
Jonathan
stuart
« Reply #5 on: December 04, 2004, 07:04:56 pm »
Thanks.
Jonathan
Using Enhanced shock will allow you jump in sooner!
« Reply #6 on: December 04, 2004, 07:11:44 pm »
At this point its basically the same water you shower and bathe in, its after you use it the first time that it might start getting yucky.
newtotubbing
  • Lovin' my Vista
« Reply #7 on: December 05, 2004, 12:13:38 am »
Ahhhhhh, just got out.
What a difference.  :o
Fresh, pure, sparkling  ;D  8)  ;)
I wonder....in the next 4+ weeks, if I fill the spa with hot water at the same time that I'm draining it,
and if I keep the flow rates equal, if I did this for and hour or two, would that really freshen up the spa much like a water change?  ??? ??? ???
Jonathan
