Author Topic: A7L Bullfrog Cost?  (Read 9044 times)
Wakefield2020
A7L Bullfrog Cost?
« on: May 11, 2020, 09:38:04 am »
I've seen the cost of an A7 or A7L anywhere fWrom $10,500 to $12,500.  What should I expect to pay?
A7L Bullfrog Cost?
NeedlenoseNed
Re: A7L Bullfrog Cost?
« Reply #1 on: May 12, 2020, 10:35:24 pm »
i landed around 9300 for an a7 after some negotiating and lots of homework across local dealers and multiple brands.
j-ice
« Reply #2 on: May 20, 2020, 11:59:39 pm »
geez that is crazy low - was that this year?  i had been quoted 11,700
BW13
« Reply #3 on: June 05, 2020, 01:24:16 pm »
9300????  That's crazy.  Did that include anything?  I just got an A7L for 10,800 with EOS3, Circulation Pump, cover, lifter and steps and delivery and installation.
« Reply #4 on: June 12, 2020, 03:10:21 pm »
Even that is a very low price
bclarr
« Reply #5 on: July 26, 2020, 09:16:31 pm »
hi....Canadian here...do we really need the EOS3 and circulation pump? my dealer is saying not worth the upgrade and it will work just fine without then....also I was quoted 13000 CAD with everything but not tax. is that a good deal? thanks for your help
BW13
« Reply #6 on: July 27, 2020, 12:01:31 am »
the eos 3 and circ pump will help you use fewer chemicals but the main advantage of the circ pump is that it's quiet.  Without the curc pump it will use the main pump and jets to circulate water through your filter.  Mine is near a window so that was important, if yours is away from your house then you may not care.
bclarr
« Reply #7 on: July 27, 2020, 09:39:27 am »
thank you - can i add this later on in my hot tub? like 1 year down the road? the hot tub will be beside my kitchen window. thanks.
Frogger
« Reply #8 on: July 27, 2020, 04:23:20 pm »
I would check with the dealer on that. I wanted a stereo on a floor unit and he said it needed to be factory installed.  Eos and circ pump are different but eos especially looks a bit involved.  I'm having both those options installed btw...
