Original > Hot Tub Forum
Artic Spa Grizzly
Tman122:
--- Quote from: 406soaker on December 14, 2019, 12:03:41 am ---https://www.arcticspas.com/arctic-spas/grizzly/
Here the Artic Spa were looking at.
--- End quote ---
This part of their insulation description is deceitful.
"Ambient heat from the pump penetrates the spa shell and heats the water. In winter this heat returns to the pump area in the event of a power loss."
Facts are in cold climate the warmth generated from the pumps creates r-factor in the cabinet. Pumps filter and create warmth for 4 hours a day, that leaves the balance of the day, 20 hours with less r-factor than the HS. And you better hope that its not "heat" heat is the enemy of hot tub equipment.
406soaker:
Thank you.
Is the ACE system installed at the factory or can that be added later on with the Flair Model? We’re trying save where we can and if I could go without the salt for now that would save us quite a bit of money based on how much I’ve seen the ACE go for on these forums.
castletonia:
ACE would be a dealer installed option. It will probably cost you a bit more to add it later than if your dealer installs it at the time of delivery since they will have to make a separate trip.
If those are the only two models you are down to, then let the wet test and dealer's credibility make the decision for you. It doesn't matter if the Arctic is $5k cheaper if you don't fit right it in.
Tman122:
--- Quote from: castletonia on December 14, 2019, 11:56:57 am ---ACE would be a dealer installed option. It will probably cost you a bit more to add it later than if your dealer installs it at the time of delivery since they will have to make a separate trip.
--- End quote ---
Yea and if the Arctic is 5 grand cheaper is not an apples to apples comparison.
ratchett:
--- Quote from: 406soaker on December 14, 2019, 10:47:56 am ---Thank you.
--- End quote ---
The new 2019 systems do not use the older expensive ACE salt system. Instead it's an inline cartridge system.
My dealer was charging the same price if I wanted the Freshwater salt or the Ozone system
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
